Hey everyone, I’m currently creating a hexagonal panel with attractor points and have hit a roadblock. When I create the offsets using a loft and surface split command from a uniform offsetsrf, the definition works just fine. But my goal for this definition is to have these panels be offset to one attractor point somewhere on the surface. I received a definition from @Joseph_Oster that I modified to get where I am currently, but now my issue seems to be with the data tree. I need some way to align this data tree so that the curves loft properly, and you can see in my images of the color coded data branches that the top faces aren’t grouped correctly. Is something like this possible to do?
Hex Cells Attractor Data Tree Problem.gh (43.1 KB)
