Im trying to close this object thats currently an open surface. Doing show edge shows me where it is open, but when I try to patch it, it won’t become a closed surface. Could anyone try to close it for me??
opensrf.3dm (988.0 KB)
Hello, I followed exactly what you said, but it is still not a closed surface
Hi Steven - well, yes - what I described is how to fix that one location - I’m afraid overall your part is actually a bit of a mess… you have surfaces that fold back on themselves, surfaces crossing one another - it’s probably worth stepping back and revising your methods… it’s hard to be of much help without knowing more about what you did with what curves…
Extract the 2 surfaces involved and run the untrim command then
click on the 2 edges ( where the X’s are in the image below)
Then select everything and join.
