hi! The nautilus plug-in is not working with my Rhino 8 on my HP computer. I keep getting an error code that pops up saying its not compatible with my Rhino 8. I’ve put this plug-in into the grasshopper library and have unblocked all 7 files, but it’s still not working. I just get loading errors instead now. Any idea on how to fix this?
Hello
thanks for the report, but you don’t gave enough element. I think it could be good you use the button “Copy As Test” and paste the result here.
Which Nautilus version do you use ? Use this component
And perhaps it has something to do with ?
There is also an email that you can use.
sorry! I’m a student just learning so I’m fairly new to everything that has to do with rhino and grasshopper. This is what I got.
I have downloaded the file twice (deleted the first one since it didn’t seem to want to open), and then read to open the library of grasshopper to add the file to it which i have done but it still doesn’t seem to want to work. I also used the last file on the Food4Rhino. not the examples. (i did download an example as I also read that i should try to activate it through a download but i still receive the same problem)
You surely forgot to put the LDLIB.dll, my plugin will not work without it.
You will need for quite sure these one (in red)
The best is to use Package Manager!
It worked! thank you!
