Hi there,
I’m a little confused. some of the plugins I had under R7 are not working (showing in toolbar) under R8. (e.g. Pufferfish, Charmeleon, and others)
Some says some plugins should show/work that arn’t showing under the toolbar for me. (for instance chameleon plugin)
** OFC I’ve unlock them before using them.
Basic questions:
1 - is the folder path still the same for GH plugins under R8 as in R7,6 ?
- %AppData%\Roaming\Grasshopper\6\Libraries
2 - Not sure to fully understand, but is the problem related to NetFrame. going from 4.8 to 7 ? this post propose a solution. Though it didn’t changed anything for me when I tried this fix.
Thank you community ![]()
