I’m having a problem with named views not scaling properly. I have several named views saved and when I click on them they appear “zoomed in”. If I change the model units, the current view then zooms based on the unit scale factor, but if I then click on the named view to restore it (even if it is the same view), the view “zooms” in again.
Is there a universal setting I’m unaware of that controls scale of named views?
Hello - named views should scale with the units change. I am not sure what you are describing - are you saving a named view then changing the units (and scaling the model), then restoring the named view, and the view is not correct?
Yes, That is what I’m seeing. Is this the default behavior? Ie; despite units being changed, and model being scaled, when restoring a named view it returns to its original view perspective, independent of units?
That was my understanding, and after I re-set all the named views back to the perspectives I intended, the views scaled properly if I changed model units and scaled the model. I can’t explain how the named views in this particular model all got scaled in the first place, however.
