As the title says, NamedPositions are not saving, lost hours of work last night
. Just ran a test file to confirm this morning, same outcome, save a file with NamedPositions, close Rhino, re-open file, nada, zilch, no NamedPositions saved ??
After some more quick testing, the problem seems to be with 6.25. If I use 6.24 it saves the NamedPositions. Not tried with V7WIP, no time at the moment
Can you please provide us with a smallish file and instructions to follow to repeat the problem?
If I can repeat it here, I can get a defect report to the developers and get it on the pile to be fixed.
Thanks
Hi John, ok just tested this again, same result, this file had 2 NamedPositions when I saved it. I closed the file, re-opened and they have disappeared
np test 2.3dm (2.8 MB)
I need the file prior to the problem, WITH the named views, so I can try opening and saving it to see them missing.
I need to duplicate the problem.
I created two named positions in your file, saved/closed the file, and reopened it.
The NPs were there.
Are you saving the files on your local SSD/HD?
Thanks
yes saving to desktop on MBP, here’s another test, same result, loses Named Positions, try it a couple of times, close Rhino 6.25 completely, then open application again, and select recent file from splash window, Named Positions disappear, nada, zilch, gone !
np test 3.3dm (2.7 MB)
Sorry to be a pest, but I’m missing some crucial step.
If I open your new file and close it, nothing was changed so there’s nothing to Save. The file just closes.
To get it to Save, I need to add a bit of geometry, then close, and I’m asked if I want to save. I click Save and reopen the file, the named Positions are still there.
Are you using Export and making a new copy in a new location or something else?
I’m running a slightly newer in-house 6.26 build. I’m not aware of any new changes.
No exporting or importing, just a new file, add some simple geometry , add a NamedPosition, then jumble the geometry around a bit, add another NamedPosition , save, close Rhino, then open again
I think the critical step in reproducing this is closing and restarting Rhino. I tried to reproduce it several times by just saving, closing, and re-opening a file and couldn’t reproduce this bug. But the first time I saved, quit Rhino, re-started Rhino, and opened the file - all Named Positions were gone.
-Kevin
yep, close the programme, then re-open file, all NP gone
Bingo!
I can reproduce it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-58609
This is strange.
If I open the file that I was experimenting with above in Rhino V6 (6.26.20133.11312, 2020-05-12) it looks like it has no Named Positions.
But if I open the same file in the V7-WIP (7.0.20133.12126, 2020-05-12)
the Named Positions are still there. Apparently they are just not being seen when the file is opened in V6.
-Kevin
yeh, just opened same file in V7 WIP and the NamedPositions are there, strange but true
I just rolled back to 6.24 and the problem exists there too.
This doesn’t seem to be a regression.
Still a bug, but not a new bug.
I tested this in Catalina 10.15.4
RH-58609 Named Position: Closing a file with NamePositions, then Quitting and restarting Mac Rhino deletes the saved named positions in the file
should be fixed in the latest Rhino 6 for Mac Service Release (6.27). Thanks again for reporting this!
Named Position lost on Windows version as well
(6.29.20238.11501, 25/08/2020)
tried to open on WIP
(7.0.20266.15205, 22/09/2020)
but nothing showing here as well.
Looks like all Named positions are lost.
Any change on the file I was working, just moving grouped objects and saving/updating positions.
I can not repeat this problem in 6.29
The fix was checked into 6.27
If you can provide an example and steps to reproduce it, please let us know.
