My WIP command prompt window always resets itself to the top
At first I thought it was because of my custom workspace. But, I just created a new scheme with which to start the WIP, that should load all the default settings, no customization at all. If I run the command prompt to the bottom, it resets itself to the top every time I restart the WIP.
Checkin’ it, thanks.
Hm - here it stays put.
I wonder if renaming this file:
“C:\Users\USER_NAME\AppData\Roaming\McNeel\Rhinoceros\7.0\settings\window_positions-Scheme__Default.xml”
with Rhino closed, then start Rhino and arrangeto taste, close and re-open Rhino… does it stick?
Yep, that seems to be the fix, thanks! I’ll try to remember that if and when it happens again…
But… what causes this, I can’t help but ask… it seems Rhino is not able to write that file correctly - if you still have the old one, can you send it to me?
(sent by pm)
