- Autocomplete commands
- Use fuzzy autocomplete
- Menu
None of them stays after closing the options panel.
Hi Piotr - So, you make the change, close Options, re-open Options and the changes have reverted, correct? Is there only one Rhino open when the changes are made? Are these the only ones that revert?
If you close Rhino, rename this file:
`“C:\Users\USER_NAME\AppData\Roaming\McNeel\Rhinoceros\8.0\settings\Scheme__Default”
and then restart Rhino, does it stick?
- The options in menu will stick
- The Image+Text won’t
- The another Default Scheme was created upon opening new session. The renamed scheme kept the toolbars but lost all the colours, displays, grid and other customised stuff so I had to rename it back to reverse changes
