Hi
I am using Rhino 7 as a student for DVC. When I try to render any of my digital models’ rhino crashes. I have tried reinstalling Rhino but it still doesn’t work. I need help urgently as the project is due soon.
Thank you
Hi
Thank you
Yes, HELP, I also have urgent deadlines and since last update Rhino crashes continuously. Terminal window shows this as last odd error…
Jun 11 11:32:06 Rhinoceros[24021] : kvImagePrintDiagnosticsToConsole: vImageConverter: kCGBitmapByteOrder16Little is not allowed on 8-bit images with pixel size of 32 bits.
Hi @isabela.dean,
Can you post a 3dm file that crashes please when you run the Render command and also post the results of your SystemInfo command run in Rhino 7? You can email tech@mcneel.com if you don’t want to post these here. My guess is that a macOS update may help or that you have the problem due to a plugin you installed.
@rene3 Please provide the same if you still need help.
1st Flower.3dm (4.3 MB)
Hi
My mac is on the latest maOS update. I have also tried rendering on a different mac, which also has the latest update, and after a day it started crashing when I rendered also.
I have also found that none of my rhino models render.
Thank you for your help
Please post the result of running the “SystemInfo” command in Rhino 7. Your file does not crash rendering it here in Rhino 7 for Mac. Did you also send in the crash report to McNeel? If so, was it from the email address you use for your forum account here?
@isabela.dean you may want to try the steps from this reply
Hi
Yes, I did send a report but I think I sent it from my other email, isabela.m.dean@gmail.com.
Here is the ‘SystemInfo’:
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05002, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Evaluation, build 2021-06-09
License details: Cloud Zoo
Expires on: 4467588-05-29
Apple Intel 64-bit macOS Version 11.4 (Build 20F71) (Physical RAM: 8Gb)
Mac Model Identifier: MacBookPro15,2
Language: en-AU (MacOS default)
Intel(R) Iris™ Plus Graphics 655 (OpenGL ver:4.1 INTEL-16.4.5)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Plus Graphics 655
Displays: Color LCD (256dpi 2x), LEN P24q-20 (123dpi 1x)
Graphics processors
Intel Iris Plus Graphics 655 (1536 MB)
Color LCD (1440 x 900)
LEN P24q-20 (2560 x 1440 @ 60.00Hz)
USB devices
VIA Labs, Inc. : USB3.0 Hub
VIA Labs, Inc. : USB Keyboard
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
Nordic Semiconductor:
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.7.21160.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.7.21160.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.7.21160.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.7.21160.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.7.21160.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.7.21160.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.7.21160.5002
Hi
Thank you so much! It worked. A huge relief.
Enjoy Rhino!
