I’m trying to influence the protrusion of louvers using attractor curves and I’ve gotten it to work with just one curve, but am struggling to find a workflow to allow 2 curves to influence the form at the same time. As you can see, only one curve is influencing the form. Any help would be great!
Vertical Louvers (3).gh (22.3 KB)
you can use Pull Point instead of Curve Closest Point, and be sure to have it set to Closest Only (default state btw):
I drew some random curves on surface as attractors because yours were not internalized, make sure to re-reference yours ![]()
Vertical Louvers (3)_Re.gh (34.7 KB)
this is perfect, thank you!
