Multi slider with minimum distance between
Good Afternoon Grasshopper community,
I am back to the world of grasshopper after taking a break for couple of years and using boring autocad in architectural practice… boy have I missed this place.
I’ve been using shapediver lately to present my models and found that forming the right inputs once the model is complex enough can be a challenge.
I was wondering if there was a way to segment a line(as per image bellow) with input sliders. Where each individual slider would have a dynamic range depended on its neighbour sliders. And on top of that if there would be a way to shorten that range by a minimum distance so the segments would not be able to be shorter than this minimum distance.
Apologies about my paint skills, this is the best tool of presentation I have on hand at the moment.
Regards,
Jonas Blazinskas
Here is a better example demo:
https://www.jqueryscript.net/demo/Multi-Slider-jQuery-Mobile/
Like this?
lines.gh (93.2 KB)
Almost but the overall length of the line should not change just the segment split positions.
additionally accomplishing a minimum distance of segment would be more complicated with that in mind?
Maybe this need scripting ; when you change a value of one slider the next one must changed
Maybe this is somewhat related …
https://www.grasshopper3d.com/forum/topics/program-constraint?commentId=2985220%3AComment%3A1284423 (see my last post there)
Yes this is a solution but i think it need more improvement
c_multisliders_percentages.gh (11.6 KB)
Hi
i find this solution but when you add a point you need to copy/paste a group called for moving point
the rest i tried to make it clear
maybe someone can convert the idea to script or by adding loop
line slider.gh (33.1 KB)
Agreed, would love to see this being packed up into a component that is supported by grasshopper as a new type of slider, is there a way for us to request something like this officially?
