I have one big mesh, and I want each node(A,B,C,D) to be rendered in a different color! more over I want the a gradient change of the color smoothly between the corners, for this rendering visual I need only the top view (left picture), but just showing you the right one so you understand it is a 3D mesh and the material will be transparent so I am expecting to see in ,multi-levels…
SEE THE EXAMPLE: render_top_perspective|690x419
