I have been modelling a runner track system. One viewport on the printed page is raytraced. If i click on it to bring up the Gumball and try to move the image, i get a spinning beach ball, then click somewhere else, the mouse disappears and the computer reboots itself. I see the Rhino Temp file still in the finder as if Rhino is open, which it isn’t. No Rhino crash report comes up, only the send to apple one.
I have attached the file here if it uploads ok. Thanks.
Deck Rolling Tray.3dm (3.1 MB)
Hi Nathan, thats interesting, I am not getting your result.
I made a copy of the file, changed that image to rendered and have no issues. As soon as I change it to RT I get the crash. It seems to disable the mouse, takes a minute or 2 then restarts the computer.
I’m on a 12 core Macpro Intel machine running Ventura 13.5.2.
I was having trouble with this file during the build up phase. Occasionally the main Rhino screen would disappear and leave the small pallet open. I would have to click the Rhino icon to get it all back.
I’ll try something new a clean file see if i can recreate the issue. Thank you.
Until any fix for this is found I suggest keeping the details in say Wireframe mode while positioning them, and only when you’re ready set them to Raytraced.
This might be related to a Metal-related crash I’ve been investigating ( RH-78648 Crash after internal Metal error ).
Hi JP -
In addition to Nathan’s suggesting to using a different display mode while positioning, note that, at this point, printing / exporting to PDF a layout with a detail in Raytraced will result in that detail being in the Rendered mode. That issue is on the list as RH-50153.
If you need a detail in Raytraced, for the time being, you could raytrace in a model space viewport, copy that viewport to the clipboard, and paste it as an image in the layout to replace the detail.
Excellent, many thanks.
