HI EVERY ONE
Can we moving two sliders together?
And what are the kinds of solvers in the program?
Why you need move two slider together?
If you move them so there is a relation between the numbers, than you can use one slider and calculate the second value.
If you know the relation between the two sliders, you can use the remap component to map one slider to the other one. So when u move one slider the second slider also moves.
thank you karizmar & seghier
The same problem I have. your answer is based on a correlation between two sliders, however, sometimes we have sliders with the specific numbers to which don’t have any relation. For example, in one slider we have (1,5,16.5) and on the other slider, we have 400 1000 1015.
Show an example or post a script
