Animate different sliders at the same time
Hi All,
I am trying to create a animation of the video below where the geometry grows and rotates. I can animate each slider individually as shown. Is there a way to animate both together at the same time. Bearing in mind that on is angle slider (degrees 0-90) and the other is a scale (0-2.00).
Best,
Felix
I would use just one slider and remap the domain of that one slider to your other desired domain
Wow! That’s a great suggestion. I had no idea such a thing was possible!
Would you mind ever so much explaining how I would remap 0-90 degrees to match a slider from 0-2.00? Or vice versa I suppose!
Use the remap component - feed your master 0 to 1 slider into the input, set the bounds you want to map from to 0 to 1 (construct domain), and set the bounds you want to map to 0-90
Slider goes from 0 to 90:
remap_2021Oct27a
You can also use this
Thanks to all of you for your suggestions. The Remap was definitely the way to go. Took some messing about with adding an expression (x-1) to the rotation components (also setting them to radians made it easier) so that they began to rotate after reaching 1 in scale; but i got there in the end!
Thanks guys!
