Moving a common end point for different curves such that all the curves stretch:
Hello, I have a few different curves connected to a single coincident point.
I want to move this point so that all the curves are affected at once. The curves must stretch, not translate. This is normal for CAD tools such as AutoDesk but I am unable to do so in Rhino, any help will be appreciated. Thank you
it is also normal for Rhino, points on and off you go
you can also set Rhino to activate Points automatically when a curve is selected, then just subsequently select each curve and then drag to select all points as Nathan pointed out.
