Internalized Bamboo Irregular.gh (50.7 KB) Good evening,
I have these bamboo poles that I would like to detail a bit more by showing the irregularities in the change in X and Y along a line at given points.
In my head I thought: Divide a curve x amount of times, then construct a domain that would then connect to random to randomize the change in position of each point. After some time, I figured out all points were moving at the same distance and vector. I further tried to list item (each point on a given line) and move them individually, but even the “0s” still move together at the same distance and vector. I know this is a simple solution but cannot figure it out, please help.
If this can become a lot more simple where I do not have to call out each point on the line “list item” that would be great to learn.
The breps are internalized
that are being manipulated.Thank you!
