Move UVN Smooth bug
Hi All,
Apparently there is a bug in MoveUVN command, when you use the smooth option for V or U, sometimes the interactive preview stops and the command crashes Rhino, the moveUVN window keeps floating appearing and dissapearing randomly while you try to close Rhino from windows task manager, but you can’t close it or cancel de command with scape.
I’m trying to share a case that you can reproduce, but it seems that it’s not responding always the same way. At least 2 times it happened with the right row selected in this image.
MoveUVN_260327.3dm (163.6 KB)
Yep, I can reproduce that. I opened RH-94372.
RH-94372 is fixed in Rhino WIP
