Move / copy objects with locked direction and coordinates
Hi all,
There is a feature I really miss in Rhino 6 compared to Rhino 5.
In RH 5 you were able to move or copy an object (for example at unknown coordinates) along the Z axis to its desired Z coordinate using the move or copy command with locked direction (Vertical=Yes) and promted coordinates.
RH 5:
The result is a transformed object with same X / Y coordinates and the given Z coordinate.
RH 6:
The result in Rhino 6 differs insofar as the locked direction is ignored and the transformation is 100% done to the given coordinates.
Is there any fast workaround for this “problem” where I do not need to check the initial coordinates of the object wanted to transform?
@pascal @stevebaer Or to implement the direction lock into Rhino 6.
Greets
Clemens
Hi Clemens,
This was fixed in https://mcneel.myjetbrains.com/youtrack/issue/RH-42677 but you won’t see it until the 6.1 service release which will be shortly after the initial 6.0 release. I know that’s a little odd from a user’s perspective considering how we haven’t shipped v6 yet… sorry for the delay.
Thanks for the info Brian, nice to know that its going to be fixed!
Greets
