Mouseover tool hints don't change in Rhino8
v8
rollout the booleans, happened to hover the Boolean split, then move to the left and everything is declared the same name.
try this on another tool, anything to left of a tool shows that tools name when mouse then moved to the left of it, so all tools seem to be the same command.
not knowing the icon the name that appears is essential, and so this is not doing what I was used to in V5.
and on a variation of this, see attached, this time I went from the ‘create solid’ to the icon I recall was boolean difference but it wasnt it was intersection, could have sworn blind I had the right one remembering the icon.
so confusing.
basic stuff.
Steve
@Steve1 I could not replicate that behavior here. Can you run _SystemInfo and post back the results?
Hi, just tried again, and still doing it, tried V5 slick no delay changes for each one.
V7, as V5.
same file open each time or similar.
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
pls update to the latest SR, that issue has been fixed.
done the update, and yes fixed.
Thanks
checked the other issue of Boolean Difference fail and fail still stands.
Steve
