Most of the VA GH components missing
I got something like this at the Rhino startup. Most of the VA GH components are gone. Rolled back one Rhino version, reinstalled Rhino and VisualARQ, nothing changed.
System Info
Rhino 8 SR11 2024-8-13 (Rhino 8, 8.11.24226.06001, Git hash:master @ bdb34e68e0160956fc5633ba163aeb8fe1301c50)
License type: Educational, build 2024-08-13
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 4-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.59
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 4-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.59
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-15-2024
Driver Version: 31.0.15.3859
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Synapse\0.4.0\SynapseRCP.rhp “SynapseRCP” 0.4.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24226.6001
An error occured during GHA assembly loading:
Path: C:\Program Files\AsuniCAD\VisualARQ 3 Beta\RHINO8\System\netcore\GhVa30.tba
Exception System.TypeLoadException:
Message: Method ‘ClearContextualData’ in type ‘VisualARQ.Grasshopper.Parameters.GhVaProductContextualParam’ from assembly ‘GhVa30, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null’ does not have an implementation.
Only one sub-group of VA GH components visible in the tab
Rolled back even more, to Rhino 8.10.24212.13001 and now it’s loading.
@Czaja
What Rhino and VisualARQ versions did you have when this happened?
What VisualARQ version do you have when this works fine?
When broke - as in the System info - Rhino 8, 8.11.24226, and the latest VisualARQ 3 Beta.
Working - version to which I rolled back to - 8.10.24212.13001, the same VA 3 Beta.
I’ve just installed the 8.11 version and got the same problem. The 8.11 is a release candidate version, which may not be fully tested. We will see if this is related to the RC or if something is broken at VisualARQ’s end.
Hi @Czaja,
This issue is due to a change in Rhino 8 SR11 RC. I’ve reported it to McNeel, and they have already fixed the issue in the next 8.11 RC, which will be published next week.
Enric
RH-83528 is fixed in Rhino 8 Service Release 11
