Morphing without SrfMorph component
Hey everybody,
I’m trying to do in python what does what the grasshopper SrfMorph component does.
actually i just want to deform a simple geometry (A) and fit it in a shape (B) that i already have.
did anyone try something like that and could maybe help me out understanding what SrfMorph does!
thanks
Not your lucky day. I have quite a few Morph
Screen Shot 064
(related with all the 8 available Cl;asses - as listed above) examples … but in C# not P. Since you can’t translate the former to latter there’s a little problem around.
yup … Not my Lucky day
not true!
you can use them, but you need to be aware that you need to care about disposal by yourself. see this maelstrom example:
Morph_PandC.gh (10.0 KB)
i just want to fit the left box in the right one using python or grasshopper.
Well … Indeed … but I had slightly more complex stuff in mind.
Morphs_twisted_V1.gh (132.5 KB)
Hi Guys,
could you please translate the BoxMorphObject code in the link [http://developer.rhino3d.com/api/rhinoscript/object_methods/boxmorphobject.htm]
from C# to Python?
Grasshopper has box morph component. You need to make the right one into a twisted box. You can do that with the twisted box component or check out my plug-in Pufferfish which has a bunch of twisted box components. You can probably use the “RefTBox” reference twisted box component which was made to turn rhino made box like geometry into a twisted box.
I see nothing in there which couldn’t be translated into Iron-Python, you just need to know how to use Rhinocommon, which is a bit difficult to deal with if you never worked with it in c#. But in theory there is hardly any limitation. Only limitation I know of: overloading custom preview like in c# is not doable, but this is due to the fact that the methods involved are part of the c# or vb.net scriptinstance. Iron-Python per se is very weird, especially if you only know Python but no C-style language.
Yes, that’s why GhPython for V6 has the “Grasshopper SDK mode”, which allows to use the exact Grasshopper class (GH_Component) which is used internally by Grasshopper and therefore any overloading is possible.
Note that Grasshopper Scripts in C#/Vb.Net do NOT inherit from GH_Component. You need to use Visual Studio to inherit from them.
