MOONG Tools: pipe cut lists & laser flat patterns for Rhino 8
Counting pipes, unfolding laser parts and drawing connector views by hand used to eat hours of every project for me.
I design pipe-frame and sheet-metal structures (playgrounds, landscape, exhibition) and order laser cutting, bending and welding myself, so I turned my own scripts into a Rhino 8 plugin.
**3D model → shop drawings**
  • Pipe cut list + hole and bent pipe sheets
- Laser flat patterns by thickness – bent parts unfolded with bend allowance (DIN 6935), bend lines as marking, clean closed outlines for DXF/DWG
- Connector 4-view sheets with dimensions
**Order quantities**
- Stock bars to order (CSV) and sheet nesting estimate by thickness
- One table with every part count
**Model clean-up**
- Group identical parts, name parts by click order, name tags on the model
10 commands · Rhino 8 for Windows · English / Korean UI · original objects are never modified
:backhand_index_pointing_right: MOONG Tools – Fabrication Drawings for Rhino 8
**Question for fabricators here:** how do you make your pipe cut lists and laser files today
– by hand, Grasshopper, or another plugin? I’d love to hear what would save you the most time next.
