Hi everyone,
I’ve been working in metal fabrication (laser cutting, bending, welding) for 7 years, mostly on pipe-frame structures, playground and landscape structures, and sheet-metal parts. Over time I wrote a set of Rhino scripts to stop doing cut lists and order sheets by hand, and I’ve now packaged them as a plug-in.
What it does: takes a 3D metal structure model and turns it into the documents you send to the shop.
- GroupSameShape – groups identical parts by real geometry, even when rotated
- ClickToName – click parts in order to name them A1, A2…; identical shapes get the same name automatically
- NameDot – shows part names as tags in the model
- PipeCutList – diameter, length and hole data for every pipe (basic / hole / bend / corner tables)
- PipeStockCount – stock pipe quantities per diameter, with cutting allowance, CSV export
- LaserCutUnroll – flat patterns with bend lines (DIN 6935 bend allowance), DXF/DWG export
- LaserUnfoldNest – sorts plates by thickness and estimates the number of sheets needed
- ConnectorSheet4View – connector sheets with front / top / right / iso views and dimensions
- QtyLayerReport – one table with counts of pipes, laser parts and connectors
- GroupPipesBySpec – groups pipes by diameter, length and hole pattern
It never modifies your original objects, and if something fails, it tells you why.
Requirements: Rhino 8 for Windows. English and Korean UI (follows your Rhino language).
Price: US$99, one user / up to 2 computers.
Gumroad: MOONG Tools – Fabrication Drawings for Rhino 8
food4Rhino: MOONG Tools – Fabrication Drawings for Metal Structures | Food4Rhino
I’d really appreciate feedback, especially from anyone doing pipe frames or sheet metal. Happy to answer questions here.
