tahirhan
(Tahirhan)
November 9, 2021, 2:49pm
1
NotilusPiping is a 3D piping solution with database integration.
with Notilus Piping you can:
easily create and edit pipes
automatically categorize pipes with a layering system (System - Dimension - Material - Diameter - Thickness)
build your custom library upon the existing database
reach to a database of valves and flanges and add to document instantly
get a Bill of Materials table in a second (pipes, isolations, valves, flanges, reducers, penetrations, elbows, etc.)
define Penetration standards and place them to structures
make channels and cable trays
automatically add reducers to connection points
Pipe creation form:
Add valve form:
BOM table form:
Add Custom Pipe to Library:
Watch the videos for more information:
Notilus Nautical Design Webinar: https://youtu.be/JjoIuMBKB5M
Notilus Piping User Guide: https://youtu.be/vHhnj7pvGt8
Notilus Piping Detailed Usage: https://youtu.be/ury4bCQdHHY
Food4Rhino Link: https://www.food4rhino.com/en/app/notilus-piping
@tahirhan why i am failed connect to server, when i want to draw pipe?
tahirhan
(Tahirhan)
July 18, 2024, 7:25am
3
Dear @Rengga_Firman_Wardan ,This issue is usually related to firewall port block. Please allow 1433 port if you are using a firewall. You may also test it with cell phone internet.
Best Regards
Ruri
(Ruri)
July 18, 2024, 9:02am
4
Is this compatible with Rhino 8?
It may be just the thing my organisation needs for industrial piping
tahirhan
(Tahirhan)
July 19, 2024, 6:45am
5
Dear Ruri,
NotilusPiping can work on Rhino 8 by changing the .NET version as explained in this link: Rhino - .NET Core vs .NET Framework
We will also integrate our plugin to .NET Core but we are waiting for a bug fix from McNeel: Moving .NET 4.8 to .NET 7 cause SqlClient PlatformNotSupportedException - #10 by curtisw
Your organisation can reach to us from software@notilusdesign.com , Also they can inspect our plugins from www.notilussoftware.com
Best Regards
