Hi McNeel’ies ![]()
I quite often use ModifyRadius, but from time to time run into the actual radius being correct - and thus not needing to change it. Instead of being able to just click enter, I have to either type the radius again or reach for the escape key, which is kind of annoying. Can it be changed so that Enter just accepts the current value (which is already there in the parenthesis)?
TIA, Jakob
thanks for reporting. Windows only.
RH-90059 ModifyRadius: accept enter to keep radius
RH-90059 is fixed in Rhino 8 Service Release 26
