Filletedge Edit - Bug?
When working with Filletedge>Edit; If I change the radius, it is not applied to the current selection. The selection reverts to the previous radius. The only way I have found around this is to drag the handles, or click and edit the handle value.
I’m not sure how this is intended to work, but that seems a little buggy to me.
Thanks,
Don
Hi Don - I’m not sure I follow - here, I click on the center blip on any handle, and I can type in a number to set that radius - does that not work,or am I doing the wrong thing?
After reading through the help file, it appears it works as it is supposed to. I was trying to enter a new value on the command line, that is not how it is described in the help file. I did find if you click SetAll you can enter a value.
Thanks,
Don
