Hello. I’m using the evaluation copy of VA on Rhino 8.
After updating to version 3.0.15, I cannot parametrically modify the window (or any other object). I’ve loaded some VAstyles from food4rhino, but they cannot be managed and are read as simple blocks (001.jpg).
I cannot change the dimensions of individual elements, either directly or through the Style properties. The Geometry tab is also missing (003.jpg)
The Styles were originally from Francesc Salla
Since this is a “Grasshopper style”, the style dialog doesn’t contain the same tabs as a regular window. For that reason, there is no “Geometry” tab. All the parameters are available under the tab “parameters”, after selecting the style root.
Ok, great! My fault. Rhino 7 problem solved.
Rhino 8 issue is still there, non chance do modifiy that window because it doesn’t appear like an editable parametric object but just as block.
I’m using VA 3.0.14 on rhino 7 and 3.0.15 on rhino 8. I couldn’t find an archive of the older Visualarq release just to downgrade to a working version (at least for my case).
Yes of course. This is also true for my older projects file I did previously. All the VA objects are just blocks and cannot be modified anymore, unless I save in rhino 7 version and open them with it.
Anyway, this is the sample file: windows_01.3dm (4.2 MB)
