Hello everyone.
I’m currently working on the EasyCut version, the script for which I’m providing below.
This script is very useful but has a limitation.
spec_cmd.py (17.7 KB)
# -- coding: utf--****
import Rhino
import Rhino.Geometry as g
import codecs
import sys
import System
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
import Rhino.UI
import scriptcontext
import math
import webbrowser
commandname = “spec”
LayersEffect = 0
DIR = {“x”:(0,1,2),
“y”:(1,0,2),
“z”:(2,0,1)}
AXES = {0:Rhino.Geometry.Vector3d.XAxis,
1:Rhino.Geometry.Vector3d.YAxis,
2:Rhino.Geometry.Vector3d.ZAxis
def computeDims(obj):
**** objRef = Rhino.DocObjects.ObjRef(obj)****
**** brep = objRef.Geometry() ****
**** edges = list(brep.Edges)****
**** edges.sort(key=lambda edge: edge.GetLength(), reverse=True)****
**** edge = edges[0]****
**** adFaces = list(edge.AdjacentFaces())****
**** faces = list(brep.Faces)****
**** adFaces = [faces[i] for i in adFaces]****
**** adFaces.sort(key=lambda face:face.GetSurfaceSize()[1]face.GetSurfaceSize()[2],reverse=True)***
**** face = adFaces[0]****
**** faceNor = face.NormalAt(0,0)****
**** origin = edge.PointAtStart****
**** xPoint = edge.PointAtEnd****
**** xVec = Rhino.Geometry.Vector3d(xPoint-origin)****
**** xVec.Unitize()****
**** yVec = Rhino.Geometry.Vector3d.CrossProduct(faceNor, xVec)****
**** yVec.Unitize()****
**** plane = Rhino.Geometry.Plane(origin, xVec, yVec)****
**** surf = Rhino.Geometry.PlaneSurface(plane, Rhino.Geometry.Interval(0,1),Rhino.Geometry.Interval(0,1))****
**** #scriptcontext.doc.Objects.AddSurface(surf)#!!!delete****
**** verts = list(brep.Vertices)****
**** worldPlane = g.Plane.WorldXY****
**** tMatrix = g.Transform.ChangeBasis(worldPlane, plane)****
**** map(lambda vert:vert.Transform(tMatrix),verts)****
**** verts = list(map(lambda vert:vert.Location,verts))****
**** verts.sort(key=lambda vert:vert.X)****
**** length = verts[len(verts)-1].X - verts[0].X****
**** verts.sort(key=lambda vert:vert.Y)****
**** width = verts[len(verts)-1].Y - verts[0].Y****
**** verts.sort(key=lambda vert:vert.Z)****
**** thickness = verts[len(verts)-1].Z - verts[0].Z****
**** return [[length,width,thickness], [xVec,yVec,faceNor]]****
class attr:
**** def init(self, name, isEditable, isOn, valType, exportPos):****
**** self.name = name****
**** self.isEditable = isEditable****
**** self.isOn = isOn****
**** self.valType = valType****
**** self.exportPos = exportPos****
ATTRS = (attr(“N”,True,True,int,1),
attr(“Name”,True,True,str,0),
attr(“Length”,False,True,int,2),
attr(“Width”,False,True,int,3),
attr(“Thickness”,False,True,int,4),
attr(“Texture”,True,True,str,-1),
attr(“Edge_L_0.4”,True,True,str,6),
attr(“Edge_W_0.4”,True,True,str,7),
attr(“Edge_L”,True,True,str,8),
attr(“Edge_W”,True,True,str,9),
attr(“Layer”,False,True,str,10),
attr(“Comment”,True,True,str,11),
attr(“Ensemble”,True,True,str,12)
QUANT_FIELD = attr(“number”,False,True,int,5)
QUANTITY_COLUMN_POS = 5
MAX_DIM_LEN = 2780
MAX_DIM_WIDTH = 2050
DIM_PRECISION = rs.GetDocumentUserText (“easy_cut_precision”)
if DIM_PRECISION==None:
**** DIM_PRECISION = 0****
else:
**** try:****
**** DIM_PRECISION = int(DIM_PRECISION)****
**** except:****
class Specification:
**** QUANTITY_COLUMN_POS = 5****
**** def init(self, attrs, details):****
**** self.details = #{}****
**** idSet = set(range(len(details)))****
**** self.table = ****
**** while len(idSet)>0:****
**** curId = idSet.pop()****
**** curDet = details[curId]****
**** curDetails = [curDet]****
**** idLst = list(idSet)****
**** for id in idLst:****
**** if curDet == details[id]:****
**** curDetails.append(details[id])****
**** idSet.remove(id)****
**** self.details.append(curDetails)****
**** self.buildTable()****
**** def buildTable(self):****
**** for details in self.details:****
**** specRow = list(details[0].getParams())****
**** specRow.insert(self.QUANTITY_COLUMN_POS, len(details))****
**** self.table.append(specRow)****
**** self.table, self.details = (list(t) for t in zip(sorted(zip(self.table, self.details), key=lambda x: (int(x[0][0]) if int(x[0][0])>0 else 9999, x[0][10], -float(x[0][4])))))***
**** def autoNum(self):****
**** i = 1****
**** for tableItem in self.table:****
**** for detail in self.details[i-1]:****
**** detail.N = i****
**** detail.refresh()****
**** tableItem[0] = i****
**** i += 1****
class SpecDialog(forms.Dialog[bool]):
**** def init(self):****
**** self.Title = “EasyCut”****
**** self.selected = ****
**** self.edgeshighlightMode = -1****
**** self.m_gridview = forms.GridView()****
**** self.m_gridview.ShowHeader = True****
**** self.Padding = drawing.Padding(10)****
**** self.Resizable = True****
**** num=0****
**** for idx in range(len(ATTRS)):****
**** if num == QUANTITY_COLUMN_POS:****
**** attr = QUANT_FIELD****
**** column = forms.GridColumn()****
**** column.HeaderText = attr.name****
**** column.Editable = attr.isEditable****
**** column.DataCell = forms.TextBoxCell(num)****
**** self.m_gridview.Columns.Add(column)****
**** num+=1****
**** attr = ATTRS[idx]****
**** if attr.isOn:****
**** num+=1****
**** self.precision_dropdownlist = forms.DropDown()****
**** self.precision_dropdownlist.DataStore = [‘1’, ‘0.1’, ‘0.01’, ‘0.001’, ‘0.0001’, ‘0.00001’]****
**** self.precision_dropdownlist.SelectedIndex = DIM_PRECISION****
**** self.precision_label = forms.Label(Text = "Dimensions precision " )****
**** self.precision_dropdownlist.DropDownClosed += self.changePrecisionVal****
**** layout0 = forms.TableLayout()****
**** cell = forms.TableCell(self.precision_label,scaleWidth=False)****
**** cell.ScaleWidth = False****
**** cell2 = forms.TableCell(self.precision_dropdownlist,scaleWidth=False)****
**** cell2.ScaleWidth = False****
**** row = forms.TableRow(None, cell, cell2)****
**** row.ScaleHeight = False****
**** layout0.Rows.Add(row)****
**** self.m_gridview.CellClick += self.gridClick****
**** self.m_gridview.SelectionChanged += self.gridSelChanged****
**** self.m_gridview.CellEdited += self.gridEdited****
**** self.m_gridview.CellFormatting += self.OnCellFormatting****
**** self.buttonAutoNum = forms.Button(self.buttonAutoNumClick)****
**** self.buttonAutoNum.Text = “Auto number”****
**** self.button = forms.Button(self.buttonClick)****
**** self.button.Text = “Export”****
**** layout = forms.TableLayout()****
**** layout.Spacing = drawing.Size(5, 5)****
**** cell = forms.TableCell(self.m_gridview)****
**** row = forms.TableRow(cell)****
**** row.ScaleHeight = True****
**** layout.Rows.Add(layout0)****
**** layout.Rows.Add(row)****
**** layout2 = forms.TableLayout()****
**** layout2.Spacing = drawing.Size(5, 5)****
**** cell = forms.TableCell(self.button,True)****
**** cell2 = forms.TableCell(self.buttonAutoNum,True)****
**** row = forms.TableRow([cell,cell2])****
**** layout2.Rows.Add(row)****
**** layout.Rows.Add(layout2)****
**** self.m_linkbutton = forms.LinkButton(Text = ‘Easycut’)****
**** self.m_linkbutton.Click += self.OnLinkButtonClick****
**** self.m_donatebutton = forms.LinkButton(Text = ‘Donate’,Style = “right-align”)****
**** self.m_donatebutton.Click += self.OnDonateButtonClick****
**** cell = forms.TableCell(self.m_linkbutton,True)****
**** cell2 = forms.TableCell(None,False)****
**** cell3 = forms.TableCell(self.m_donatebutton,False)****
**** row = forms.TableRow([cell,cell2,cell3])****
**** self.Content = layout****
**** def changePrecisionVal(self, sender, e):****
**** global DIM_PRECISION****
**** DIM_PRECISION = sender.SelectedIndex****
**** rs.SetDocumentUserText (“easy_cut_precision”, str(DIM_PRECISION))****
**** specification = self.spec.details****
**** for row in specification:****
**** for det in row:****
**** det.setDims()****
**** self.rebuild()****
**** def OnCellFormatting(self, sender, e):****
**** if float(self.spec.table[e.Row][2]) > MAX_DIM_LEN:****
**** e.BackgroundColor = drawing.Colors.Red ****
**** def setData(self, spec):****
**** self.spec = spec****
**** self.m_gridview.DataStore = spec.table****
**** def rebuild(self):****
**** self.spec.buildTable()****
**** print self.spec.table****
**** self.m_gridview.DataStore = self.spec.table****
**** def setObjs(self, dic):****
**** self.objs = dic****
**** def unselectAll(self):****
**** for det in self.selected:****
**** det.unselect()****
**** def gridClick(self,sender,e):****
**** row = e.Row****
**** col = e.Column****
**** dets = self.spec.details[row]****
**** if col >= 7 and col <= 10:****
**** self.edgeshighlightMode = (col - 7)%2****
**** self.unselectAll()****
**** if self.edgeshighlightMode>=0:****
**** for det in dets:****
**** det.getEdges(det.lcs[self.edgeshighlightMode])****
**** else:****
**** det.select()****
**** self.selected += dets****
**** scriptcontext.doc.Views.Redraw()****
**** def gridSelChanged(self,sender,e):****
**** dets = ****
**** for row in sender.SelectedRows:****
**** dets += self.spec.details[row]****
**** for detLst in self.spec.details:****
**** for det in detLst:****
**** det.unhighlighAll()****
**** if self.edgeshighlightMode >=0:****
**** else:****
**** def gridEdited(self, sender, e):****
**** cols = self.m_gridview.Columns****
**** attr = cols[col].HeaderText****
**** val = self.m_gridview.DataStore[row][col]****
**** if attr == “N”:****
**** try:****
**** int(val)****
**** except:****
**** val=dets[0].N****
**** self.m_gridview.DataStore[row][col] = dets[0].N****
**** rs.MessageBox(“number can be only an integer”)****
**** setattr(det, attr, val)****
**** det.refresh()****
**** def buttonClick(self, sender, e):****
**** data = ****
**** nameRow = ****
**** cols = [i.HeaderText for i in self.m_gridview.Columns]****
**** i = 0****
**** num=0****
**** curRow = ****
**** while i < (len(cols)):****
**** if i == QUANT_FIELD.exportPos:****
**** exportPos = QUANT_FIELD.exportPos****
**** if exportPos>0:****
**** nameRow.append((exportPos,cols[i]))****
**** i += 1****
**** else:****
**** exportPos = ATTRS[num].exportPos****
**** if exportPos>=0:****
**** num+=1****
**** i += 1****
**** nameRow = [i[1] for i in list(sorted(nameRow, key = lambda x: x[0]))]****
**** data.append(nameRow)****
**** for dataRow in self.m_gridview.DataStore:****
**** i = 0****
**** num=0****
**** curRow = ****
**** while i < (len(dataRow)):****
**** curRow.append((exportPos,dataRow[i]))****
**** i += 1****
**** else:****
**** num+=1****
**** i += 1****
**** curRow = [i[1] for i in list(sorted(curRow, key = lambda x: x[0]))]****
**** data.append(curRow)****
**** ExportObjBBData(data)****
**** def buttonAutoNumClick(self, sender, e):****
**** self.spec.autoNum()****
**** def OnLinkButtonClick(self, sender, e):****
**** webbrowser.open(“https://easycut3d.online”)****
**** def OnDonateButtonClick(self, sender, e):****
**** webbrowser.open(“easycut3d.online”)****
class Detail:
**** def init(self, obj):****
**** self.obj = obj****
**** self.selected = 0****
**** self.id = obj****
**** attrs = rs.GetUserText (obj)****
**** attrs = [i.name for i in ATTRS if i.isEditable]****
**** for attr in attrs:****
**** setattr(self, attr, rs.GetUserText (str(obj), attr))****
**** self.setDims()****
**** objRef = Rhino.DocObjects.ObjRef(self.id)****
**** obj = objRef.Object()****
**** index = obj.Attributes.LayerIndex****
**** self.Layer = scriptcontext.doc.Layers[index].Name****
**** def setDims(self): ****
# bb=rs.BoundingBox(self.obj)
# if bb:
# x=round(bb[1].X-bb[0].X,DIM_PRECISION)
# y=round(bb[3].Y-bb[0].Y,DIM_PRECISION)
# z=round(bb[4].Z-bb[0].Z,DIM_PRECISION) ****
# else:
# x=0 ; y=0 ; z=0
# self.dims = [x,y,z]
**** self.dims, self.lcs = computeDims(self.obj)
# texture = self.Texture
# if texture in DIR:
# dir = DIR[texture]
# self.Texture = texture
# self.lcs = dir
# else:
# dir = [0,1,2]
# self.lcs = [i[0] for i in sorted(list(enumerate(self.dims)), key = lambda x:x[1])]
# self.lcs.reverse()
# self.dims.sort()
# self.dims.reverse()
# alert = “texture missing”
# x,y,z = self.dims[dir[0]],self.dims[dir[1]],self.dims[dir[2]]
# if z>y:
# self.dims = [x,z,y]
# self.lcs = [self.lcs[0],self.lcs[2],self.lcs[1]]
# else:
# x = self.dims[0]
# y = self.dims[1]
# z = self.dims[2]
**** self.Length = format(self.dims[0],‘.’ + str(DIM_PRECISION) + ‘f’)****
**** self.Width = format(self.dims[1],‘.’ + str(DIM_PRECISION) + ‘f’)****
**** self.Thickness = format(self.dims[2],‘.’ + str(DIM_PRECISION) + ‘f’)****
**** def select(self):****
**** self.selected = 1****
**** rs.SelectObject(self.id)****
**** def unselect(self):****
**** if self.selected:****
**** rs.UnselectObject(self.id)****
**** def getParams(self):****
**** params = ****
**** for attr in ATTRS:****
**** name = attr.name****
**** params.append(getattr(self, name))****
**** return params****
**** def highlightEdges(self, dir):****
**** pass****
**** def refresh(self):****
**** rs.SetUserText (str(self.id), name, getattr(self, name))****
**** def getEdges(self, dirVec):****
**** id = self.id****
**** nor = self.lcs[2]****
**** objRef = Rhino.DocObjects.ObjRef(id)****
**** brep = objRef.Geometry()****
**** faces = brep.Faces#doesn’t work for extrusions****
**** edges = ****
**** for face in faces:****
**** obj.HighlightSubObject(face.ComponentIndex(), False)****
**** cond1 = (round(faceNornor)==0) perpendicular***
**** cond2 = (round(faceNordirVec)==0) perpendicular***
**** if cond1 and cond2: ****
**** obj.HighlightSubObject(face.ComponentIndex(), True)****
**** def unhighlighAll(self):****
**** def eq(self, obj):****
**** return (self.getParams() == obj.getParams())****
def makeDetail(keys, objs):
**** if not objs: return****
**** for obj in objs:****
**** for key in keys:****
**** cur_keys = rs.GetUserText (obj)****
**** if key not in cur_keys:****
**** rs.SetUserText (obj, key, “0”, False)****
**** else:****
**** val = rs.GetUserText (obj, key)****
**** if len(val)<1 or val==" ":****
def main():
**** msg=“Select polysurface objects to export data”****
**** objs = rs.GetObjects(msg,16,preselect=True)****
**** extrusions = ****
**** rs.UnselectAllObjects()****
**** if rs.ObjectType(obj)==1073741824:****
**** extrusions.append(obj)****
**** if len(extrusions)>0:****
**** rs.SelectObjects(extrusions)****
**** resp = rs.MessageBox (“Selected objects will be converted to polysurfaces.\n Press OK to continue, Cancel to abort”,1)****
**** if resp == 1:****
**** rs.Command(“ConvertExtrusion _Enter”)****
**** else:****
**** return****
**** keys = [i.name for i in ATTRS if i.isEditable]****
**** makeDetail(keys, objs)****
**** details = ****
**** spec = dict()****
**** ids = dict()****
**** detail = Detail(obj)****
**** details.append(detail)****
**** spec = Specification(, details)****
**** dialog = SpecDialog()****
**** dialog.setData(spec)****
**** Rhino.UI.EtoExtensions.ShowSemiModal(dialog, Rhino.RhinoDoc.ActiveDoc, Rhino.UI.RhinoEtoApp.MainWindow)****
def ExportObjBBData(data):
**** filter = “CSV File (.csv)|.csv||”****
**** filename = rs.SaveFileName(“Save data file as”, filter)****
**** if not filename: return****
**** file = codecs.open(filename, encoding=‘utf-8’, mode=‘w+’)****
**** s = “”****
**** for itm in data:****
**** itm = [ i if isinstance(i, str) else str(i) for i in itm]****
**** s += “,”.join(itm)****
**** s += “\n”****
**** file.write(s)****
**** file.close()****
def RunCommand( is_interactive ):
**** main()****
**** return 0****
RunCommand(True)
For example :
If I perform the operation on these two furniture boxes, the dimensions are automatically sorted by Length, Width, and Thickness, from largest to smallest.
Furniture boxes.3dm (11.7 MB)
For example, for those pieces, I would like Length=262; Width=560; Thickness=19 and Length=133; Width=697; Thickness=23
I’m thinking of several solutions that I don’t know how to implement:
the order of dimensions follows the direction of the texture.
otherwise, specify a condition to order the dimensions for the 5 piece categories (colors) below.
There may be other solutions I haven’t thought of.
Thank you for your valuable help. I’m at your disposal if you need any further information.
