Hi, you can’t do it like this. Cut plane - that’s Tekla object, you change it, not a beam. Also you can’t do something with Tekla object using Grasshopper function, you should cast Tekla to Grasshopper:
After a moving GR plane you can do something with Tekla cut plane just throw C#.
I asked ChatGPT about this code, it looks ok, but I didn’t test it. You can start with it:
using Tekla.Structures.Model;
using Tekla.Structures.Geometry3d;
using Tekla.Structures.Model.UI;
// Inputs:
// cutObject: existing Tekla cut object (e.g., CutPlane)
// ghPlane: Grasshopper Plane
private void RunScript(object cutObject, Plane ghPlane, ref object A)
// Validate inputs
if (cutObject == null || ghPlane == null)
A = "Invalid input.";
return;
var model = new Model();
if (!model.GetConnectionStatus())
A = "Tekla model is not connected.";
return;
// Convert Grasshopper plane to Tekla Structures plane
Tekla.Structures.Geometry3d.Plane teklaPlane = new Tekla.Structures.Geometry3d.Plane
Origin = new Point(ghPlane.OriginX, ghPlane.OriginY, ghPlane.OriginZ),
AxisX = new Vector(ghPlane.XAxis.X, ghPlane.XAxis.Y, ghPlane.XAxis.Z),
AxisY = new Vector(ghPlane.YAxis.X, ghPlane.YAxis.Y, ghPlane.YAxis.Z)
// Update Tekla cut plane
if (cutObject is CutPlane planeCut)
planeCut.Plane = teklaPlane;
if (!planeCut.Modify())
A = "Failed to modify the cut plane.";
return;
model.CommitChanges();
A = "Cut plane updated successfully.";
else
A = "Input object is not a CutPlane.";
@YAHOR thank you so much i to got help from chatgpt and made it work below code solved now i can modify the cut plane
using TSM = Tekla.Structures.Model;
using TSG = Tekla.Structures.Geometry3d;
using RhinoPlane = Rhino.Geometry.Plane;
// Connect to Tekla model
var model = new TSM.Model();
A = "No Tekla model connection.";
return;
// Cast Tekla CutPlane
var cut = planeCut as TSM.CutPlane;
if (cut == null)
A = "Input is not a Tekla CutPlane.";
return;
// Cast Rhino plane (value type = cannot use 'as')
if (!(ghPlane is RhinoPlane))
A = "Input plane is not a Rhino.Geometry.Plane.";
return;
RhinoPlane rPlane = (RhinoPlane) ghPlane;
// Build Tekla model Plane
var tPlane = new TSM.Plane
Origin = new TSG.Point(rPlane.Origin.X, rPlane.Origin.Y, rPlane.Origin.Z),
AxisX = new TSG.Vector(rPlane.XAxis.X, rPlane.XAxis.Y, rPlane.XAxis.Z),
AxisY = new TSG.Vector(rPlane.YAxis.X, rPlane.YAxis.Y, rPlane.YAxis.Z)
// Apply and commit
cut.Plane = tPlane;
if (!cut.Modify())
A = "Failed to modify the CutPlane.";
return;
A = "Cut-plane updated successfully.";
