Model Domo with rectangular structure
Hi Guys, i recently started studying Grasshopper and I’m trying to build a dome with a rectangular structure - for both horizontal and vertical profiles. All I have found on YouTube is about circular structures.Something like this image.
What I have done so far is as follows:
Domo - Casca_20.04.gh (9.1 KB)
Thank you for your attention
can you sketch your intended structure?
because technically speaking a dome cannot have an orthogonal structure.
if you’re after a structural system that looks like deformed squares,
here’s the file
Domo - Casca_20.04 [deformed square].gh (15.7 KB)
Oh! Yes, thank you! I misspoke. I am looking for a dome with a structure in rectangular shapes. I will fill the empty spaces with glass and wood. But what you sent will be very useful, I just have one question:
how do I extrude the rectangular surface?
use offset brep with solid set to true
thanks!! It worked, i did it :smiley:
