Hi, are mobile construction planes (MPlane) View dependent ?
Does switching views from Top to Perspective etc restore the Construction plane to default ?
I’ve noticed that if I set a mobile construction Plane in one view (top) then switch views a few times the mobile construction plane is no longer active.
What am I doing wrong ?
Regards.
Mike.
No a Mobile cplane is a cplane you can attach to objects so if you move the object or reorient it the cplane moves with the object.
You can refresh your mobile cplane in two ways one is the command… Refresh mplane
! _Mplane pause refresh enter
Or move your object and then undo the move should bring back the mobile cplane.
You’re not doing anything wrong once you change a cplane (accidentally or not) Rhino thinks you want to use that cplane, but it’s easy to always get your mplane back. I use the command a lot it’s one of rhino’s coolest features.
RM
