Does anyone know how to make a custom construction plane view, specifically for an elevation view? My model is in an angle and was wondering if there is a way to set the front view on the angle of the model? I would rotate the model, but I have tons of layers locked and off. Switching the layers back and forth is very time consuming. Any suggestions?
NamedCPlanes may be what you’re after.
I see the idea. How would it work? it will save the view? I was thinking on rotating the model so it faces the view I want, save the view and switch it back to its original position. Would that affect it at all? I appreciate the help in advance.
Hi - I would:
- use
Cplane > 3Point
to set the CPlane to a surface that you want in your elevation - use
Plan
to set the view orthogonal to that Cplane - use
NamedView
to save that view
You can then easily switch between the elevation views and have your CPlane attached to it.
