Is there a miter command. I do a lot of extruding of moldings into corners. I’d like to boolean split/trim/cut them both at an angle. usually 45. Currently I draw a line and split. I’d love to cut that step. The red line.
i would use this so much!
i started to make a script for it a while ago but didn’t get very far with it.
i was then going to make a request here for someone to make one but didn’t get around to that either.
so, no point other than +1
(oh— but if someone does make a script, please make it Mac compatible )
Yes. I sometimes use SolidPtsOn to do the same. However, I have often snapped to the wrong point. Also in a room with lots of corners doing it for each gets tedious. Laying in the elements then boolean trim/cut/delete would be much quicker.
that’s the way i do it usually… (moving edges)…
but when you’re doing a lot and doing it often, it gets kinda old
also, depending on the profile, it won’t always work… (so then it’s CutPlane, BooleanSplit, delete unwanted)
Gracias! That speeds up things a bit.
