hi. I have a problem with space syntax. As you see some components are missing and the others are repetitive. can you help me?
thanks for your help. I did but the same problem happened again
Have you made sure that all files are unblocked?
Check the version of Rhino and space syntax you have. you could try an earlier version https://sites.google.com/site/pirouznourian/syntactic-design?authuser=0
I have the same problem, did you manage to solve it ?
