Hello!
I’m using Rhino V5 SR14 64-bit with Windows 7 running on Parallels on Mac. I last used Rhino about 2 months back, and when I opened it again recently, I get an error message, and after that Rhino comes up but with missing toolbars.
The error message says:
Rhinoceros 5.0 Plug-in failed to load.
It appears Rhino failed to load the plug-in
c:\Program Files\Rhinoceros 5(64-bit)\Plug-ins\Toolbars\Toolbars.rhp
the last time you used Rhino.
Do you want to stop using this plug-in?
Yes/No
I’ve tried ToolbarReset but nothing happens.
I’ve tried Tools > Toolbar Layout, but then I get a command error message saying:
The “Rhino Toolbars and Menus” plug-in could not be loaded, but it is required to run the Toolbar command.
I’ve checked my system files, AppData > Roaming > … > 5.0 > UI, and it seems I still have a Rhino Toolbars file type called “default” in the folder.
I can still use the commands if I remember them, just that the missing buttons are quite a problem for the rest of the commands that I can’t remember.
I haven’t made (at least as I’m conscious of
) any major changes to my Windows/Mac OS or to the software/system files, or any new installations recently.
Would anyone know how to get them toolbars back?
