I’m still seing it , even after opening the file for 100th time.
Hi Piotr - I thought that we had settled this when this was discussed a month ago.
So - you don’t want to change that font to something that is available on your system?
And you do understand that if/when both you and the original author of that file print out a layout, the result will not be the same?
You suggested adding an OK, I got it button. What, exactly, would that do?
I’d be happy to see ‘Ok, don’t show it again’.
Strangely, it’s gone in the last two openings.
I would like to permanently replace a font in a file so I don’t get this dialog any more:
And I would like to know what objects have the missing font assigned, could you look into that please?
