Font is getting changed when printing a layout to pdf
hi guys I’m having an issue with printing. the font on my layouts keeps getting changed when i print as a pdf. the font shows correctly in the print preview but once i open the pdf a different font is shown. i see some other people having similar issues on here there doesn’t seem to be a solution yet
Any solution? I have the same problem with the Rhino PDF printer on mac. Also, I can’t see any option to “Save as PDF” through Adobe. All my fonts (Helvetica Neue Thin or other weights) are being changed to Arial in the PDF…
This issue is very urgent for me, friends. Hope to get any reply soon. Thank you in advance!
Any expert, who can help?
Hi Kemal,
Please run the systemInfo command in Rhino and post the results, a small example file would be helpful as well. Thanks!
Hi Japhy, thank you for your response. Attached, you can find the files.
systeminfo.txt (12.9 KB)example.3dm (2.2 MB)
vector_wrong.pdf (27.6 KB)raster_correct.pdf (2.4 MB)
Hi Kemal,
Thanks for reporting RH-86510 .
Did this work for in a previous release of Rhino 8? A quick test of saving down to Rhino 7 worked as expected.
Hello, I guess I always had this problem with Rhino 8… Wanted to try the “PDF-Save as PDF” option on mac, through the Adobe PDF printer, but I cannot find this option in the print window in Rhino. In other softwares it always appears when printing.
Will anyone work on this?
Its still in the queue. It is marked for 8.x so would expect some action on it before too long.
I´m having the same issue here (see screenshots) running Rhino 8 on a MacBook Pro M1 Max…
any solution in sight?
