I Greg
In the latest Wip Make2d missing a lot of visible lines . See the attached file
Ciao Vittorio
Make2dMissing_lot_of_lines.3dm (1.6 MB)
I Greg
Ciao Vittorio
First angle projection is making these lines here in the latest internal build of the day… please check again with the next public WIP and let me know if you still have an issue.
Hi Brian
I downloaded and installed the new version
rhino_en-us_6.0.16180.10071
but the result is always wrong
Ciao Vittorio
I just tested again in the internal daily build Rhino 6 SR0 2016-6-30 (Public Build, 6.0.16182.20051 and it’s working fine. Please try again after the next public WIP goes out which should be next Tuesday… Thanks!
thank you for your interest
Vittorio
I downloaded the last version en-us_6.0.16187.11041 , but the make 2d hawe the same problem , missing some visible lines
Vittorio
You’re not running the new WIP. It does not have any of the changes the developer has been working on. Your WIP was build on Tuesday June 28th.
The current WIP was built on July 5th.
When I run Make2D in your file in the view supplied, like Brian, I’m getting a much more complete set of 2D curves in the current in-house build.
Please update and give it another go.
I do know that the developer is still working on Make2D fixes. It’s not finished. I think there are still some issues related to silhouettes.
It’s still a Work-In-Progress
Hi John
I running in the new WIP ma the result is the same. Mine is just a bug report.
