While watching a tutorial I saw a command like this. What is the name of this command?
as far as I know that is not a native Rhino icon.
I guess it’s a set of two commands:
_Mirror _X
_Mirror _Y
So is it difficult to add this? And how can I add it?
The Rhinoceros Help explains the process
Hi !
A quick question -
How do you get standard icons with different colors ?
Thanks !
In Rhino 7 you can edit the colors in the internal button bitmap editor or an external paint program.
In Rhino 8 the icons are vector based, the internal editing capacity is currently limited, you will probably need to edit the .svg button files in an external editor.
Hi ! My mistake , I thot this was a RH-6 thread . I’ll re-post over there
Thanks -
C .
Rhino 6 is the same as Rhino 7 regarding icon bitmap editing.
