Is there an easy way to adjust Custom Display Mode that’s been imported into Rhino 7 (from Rhino 6) to be rendered equally as it was originally? Rhino 7 renders it with a gloss, whereas I’d prefer to be as it was in version 6.
I looked through Custom Display Mode’s settings but couldn’t find a way.
Both mountains in the first post have “Rendering material” checked in Display mode (exact same *.ini file), only V6 renders those textures clean, whereas V7 adds a little bit of glossy overlay which makes objects harder to workt with and analyze/ present to clients.
Hi Harry - the material on that object has 100% reflectivity, but the reflection color is set to black or dark gray, hence the gloss effect. Set that to zero.
