xerim
(xerim)
1
For some reason, I can’t get the MeshFromPoints command to work. Whenever I call it, I get this error:
When checking to see if I have the plugin installed in my plugin directory, I can see that it is there.
When checking the PluginManager to see if the plugin is enabled, I can see that it is indeed enabled
What is going on here? I’ve had this problem on multiple computers.
pascal
(Pascal Golay)
2
Hello - can you please run SystemInfo in Rhino and post the results?
xerim
(xerim)
3
I don’t seem to have this command, I am using Rhino 5
pascal
(Pascal Golay)
4
Hello - @xerim - I forgot the routine in V5 - you need to close Rhino and replace the plug in
c:\Program Files\Rhinoceros 5 (64-bit)\Plug-ins\MeshFromPoints.rhp
with the downloaded one.
