Hi!
I’m trying to create roads on a terrain, but when I use the mesh split the result does not seem to correspond to the input. Any idea what I’m doing wrong, and how to fix it?
Thank you!
Kaj
Grasshopper, Meshsplit help.gh (62.4 KB)
Hi!
Thank you!
Kaj
This mesh is created very far from the origin. Move it closer to the origin for better results. I tried with Rhino 6 and 7, both latest releases. Neither did a perfect job. However, V7 only has some issues with very near vertices (I’ll try to see why, this is logged at RH-67378) and they can easily be solved by running align vertices.
The mesh is placed far from the origin. Rhino 6 does a better job near the origin (I’ve added an automatic part to the definition that moves near the origin).
Still, some areas are not OK in Rhino 6:
Besides the issue that is fixable with Align, Rhino 7 spits the mesh in most places and allows to pick different pieces:
I’m taking this as a good example to keep improving mesh split in the coming versions of Rhino. I think we have come a long way already, and more improvements are still coming.
I am attaching the definition:
Meshsplit-7.gh (68.0 KB)
Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Hi Giulio!
Thank you for your quick response!
I tried moving the model to the center, and it worked a little bit better, but still had some issues.
It’s great that improvements are coming! Do you have any suggestions on workarounds in the meantime?
Kind regards
Kaj
OK; Yes. Which version of Rhino are you using? Please send the exact version that prints with the _SystemInfo command. For example, Rhino 7 SR15 2022-1-29 (Rhino 7, 7.15.22029.15001, Git hash:master @ 563f52d8960b56c40f3c1e22169400f16a294d11)
Thank you.
This is the version: Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
Thank you!
Can you tell which part is not working properly? So I can concentrate the effort!
Thank you,
Thanks,
Giulio
Giulio Piacentino
giulio@mcneel.com
