Is there a command or setting that will allow a Mesh Density based on curvature of surfaces ?
In the attached example, you can see the variation in an AutoCAD 3d model.
That’s what this mesh control does.
Mesh facets are flat. Think of this control as the “Chord height” you will allow the mesh to pull away from your curved surface.
Thanks, BUT where do I find this Polygon Mesh Detailed Options ?
I found it, MESH command.
Hello John;
I have tried all the options and the Quads still remain very squarish. I can’t quite seem to get the flatter surfaces to have elongated triangles or quads ?
