Hi, I am struggling with unit change when making shell mesh.
When I change unit from “m” to “mm” with setting component, the mesh is broken. Model info says, “Mesh face 4: area smaller than limit_area. Will be removed, …”.
When I make mesh with donuts ring as pics with “m” unit, the mesh is renewed when changing its diameter. However, when I do that with “mm” unit, the mesh is broken.
I have tried two methods by referring past threads.
I read this thread and made LDist smaller by 10^(-6) from 10^(-3) as “m” is 1000 times larger than “mm”.
I also checked shell thickness and changed from 1cm to 0.001cm but it is still broken.
in Karamba3D the snapping distance LDist needs to be set at the component where the elements get created (MeshToshell, LinetToBeam,…) and where the model gets assembled. See here: Circle_v2_cp.ghx (479.2 KB). Then it works.
The unit selected at the ‘Settings’-component applies to the input of geometry objects only, not to the length units at the component inputs. For the latter one can specify “CustomUnits”.
I understood and was able to run without error! I really like the concept of Karamba3D to give a use experience that goes beyond the boundaries of CAE.
