Bug: Rhino 8 unit system wrong by factor 10?
this is the cushion of a train seat. Szene unit are millimeter. I set for the mesh max length 10 and max error 1 but it looks like max length 100 and error 10. I export an obj to MoI for meshing and here the same, anything is handled like the scene unit would be centimeter. Looks like there is something wrong with the internal units. Please check and if necessary fix it as soon as possible, since it’s essential for the daily work.
Best-
Micha
WrongUnit.3dm (401.2 KB)
Hmm, not seeing that here - I made a 500mm cube and meshed it with min and max edge lengths=10 (to force the edges to be at 10) and another with min/max=100.
The 100 setting looks like it is not meshing correctly though, it ignores my max length setting in spots and makes these weird triangles which shouldn’t happen. V7 does the same.
Dunno, it measures 37 x 38 x 10 millimeters - I would say the dimensions should be in cm if it’s real-size, unless the model is supposed to be 1:10…
Thank you very much for testing it, it was a false alarm, sorry. I see now my client send me the model with wrong units. Easy to fix here. :slight_smile:
