Mesh boolean union problem
Dear developers, here’s a file with two mesh parts I client created / modified in Blender.
The two meshes don’t boolean union in Rhino 8 WIP but do so instantly in Rhino 7.
two_meshes_that_do_not_boolean_union_in_rhino_8_wip.3dm (515.1 KB)
I just tried a MeshBooleanUnion in the V8 WIP and it worked fine.
Did you use BooleanUnion or MeshBooleanUnion in the WIP?
Are you running the current WIP?
Thanks for your reply @John_Brock I tried this yesterday with the latest build and today again after updating and it does not work. I used MeshBooleanUnion.
My System Info
Rhino 8 SR0 2023-2-21 (Rhino WIP, 8.0.23052.12305, Git hash:master @ b52fe2b2d76e3a7ba202e3773b511edc5c148c93)
License type: Kommerziell, build 2023-02-21
License details: Cloud Zoo
Expires on: 2023-04-07
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 2-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.49
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 2-2-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-2-2023
Driver Version: 31.0.15.2849
Z-Buffer depth: 24 bits
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23052.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.23052.12305
It doesn’t look like you’re actually running the command.
  1. Start the command
  2. Select both meshes
  3. Press Enter
That does not change anything. Preselect or not it fails.
My units in Rhino 8 WIP:
I copy pasted the two objects to Rhino 7 and hit the command and the two meshes are unioned.
My units in Rhino 7:
Interesting…
I just updated to a newer WIP and it fails for me now too.
I’ll get it on the pile.
Thanks :slight_smile:
I’ve isolated when the change went into the WIP that broke this case, and added a defect report for the developer.
Thanks for the report and sample file.
RH-73146 is fixed in Rhino BETA
