Hi…,
I am a mesh dummy. Shouldn’t boole (e.g. _MeshBooleanIntersection) a mesh and NURBS result in a mesh? Attached an example: Boole_Mesh_and_NURBS_does_nothing.3dm (934.2 KB)
Thanks
Michael
Hi…,
Thanks
Michael
Works fine here with MeshBooleanUnion, selecting the mesh first and then the sphere.
Hi Martin,
thank you for your result. What Rhino are you using?
Here in the current WIP (8.0.23150.10305, 2023-05-30) nothing happens.
Thanks
Michael
I just realized the boolean union above was done in Rhino 7.
I’m using Rhino feeder to open files and it opened your file in Rhino 7…
I’m on the same Rhino 8 WIP like you and I see the same problem.
It seems Rhino 7 automatically converts a brep to a mesh but Rhino 8 WIP doesn’t do that.
Haha, did not see the underside of this cube is actually open. Thanks Charles.
The cleaner look of the cube in V8 is because it’s showing ngons. This can be achieved in V7 too.
Still the open result in (8.4.24023.15001, 2024-01-23).
Seems the issue was not logged.
@Gijs Do you know?
Here conversion is done to mesh, but indeed leaves an open mesh
RH-80061 MeshBooleanUnion: open result
