And if I use UnrollSrf (just after the extrusion, or after re-joining the surfaces), it’s considerated as 2 different surfaces (this is my biggest problem, as I nees to unroll the cylinders).
Is there a command similar to “MergeAllCoplanarFaces” to fix the surface of the cylinder, or does anyone know another method? (rebuild I think is kind of dangerous because you don’t get exactly the same geometry as before)
MergeSrf is the simplest method to merge two open cylinders into a single cylinder if the seams are aligned. If the seams are not aligned use Srfseam to move on of the seams until it aligns with the other.
