MergeAllCoplanarFaces doesn't work as expected!
Merge Coplanar faces should merge all these faces but it didn’t!
Merging problem.3dm (9.2 MB)
Rhino 8 SR3 2023-12-20 (Rhino 8, 8.3.23354.09001, Git hash:master @ 235baa4e9ef85abea58956ee7ff4a477d53a4188)
License type: Evaluation, build 2023-12-20
License details: Cloud Zoo
Expires on: 2024-03-12
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [73% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot12RhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.3.0.0\KeyShot2023RhinoPlugin\Rhino 7\KeyShot2023RhinoPlugin.rhp “KeyShot12RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\export_SKP.rhp “SketchUp Export”
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\export_STEP.rhp “STEP Export”
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.23354.9001
C:\Program Files\Rhino 8\Plug-ins\Export_FBX.rhp “Export_FBX”
C:\Program Files\Rhino 8\Plug-ins\import_IGES.rhp “IGES Import Plug-in”
you have some micro-Surface-Stripes in there…
EDIT
zoomed in it looks like this - which is not planar…
to fix it you have to redraw this section / wall.
make sure to use proper object-snaps or numeric input
I recommend to draw some guidance / construction lines in top view (project on)
be careful as you have some ugly tiny imprecision:
19.998 instead of 20.000 in y-direction
use _distance to check - it will also give a dx dy dz value…
It was a rush modelling, my fault!
Does Rhino have commands for troubleshooting this kinda errors ? or you drew those dots manually
its going to be difficult as you have doors etc. otherwise you could get the outline in 2d in topview as a polyline and use simplify polyline before extruding…
I did those dots manually.
I found the errors by sub-Selecting (ctrl+shift + left click) single faces and delete them … then those stripes remain.
on possible way to find those short edges:
… on a separate layer…
_dupEdge (rectangular Select all)
_explode
_selShort (use 0.1 as threshold for example)
(_extractPt if you want to view them more clearly as points)
